Panel Orientation
Gazz
Solar Expert Posts: 38 ✭
I have the decision to make in placing a panel which will get a small amount of shading. If the shading will start from the bottom of the panel is it best to fit is landscape or portrait. The reason for asking is that I have read that panels are divided into 3 section that run the "long way" (across in landscape). So if I had say 6inchs of shading in landscape it would effect 1 section but in portrait it would effect 3, is that right.
Panels are Sanyo HIT 240
Re: Panel Orientation
There is no "standard" for how panels are wired internally
Maybe the easiest way is get a sample of your panel, hook up a meter, andshade it with cardboard and see what works best. do it at the dealers parking lot if you have to, or call the factory and see if there is an engineer that can help
MikePowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
