OutBack temp sensor
offgrid
offgrid Registered Users Posts: 20
Hello everyone,
Have any of you experienced the temp sensor losing it's "stick" on the battery post ? What can I do to fix ?
Thanks !
  • techntrek
    Re: OutBack temp sensor
    Chewing gum, duct tape, pine sap, duct tape...
  • Vic
    Hello off..
    You should be able to scrape off the old double-sided tape and replace it with new (a single-dege razor blade should be perfect for the task).
    You could prob glue the sensor down with RTV/Silicone, which is good adhesive, but also easily removable should you wish to move it later.
    Vic
  • offgrid
    Thanks Vic,
    I thought about the silicon, but I like the idea of scraping/replacing tape.
  • dwh
    techntrek wrote: »
    You forgot staples.
    "Windows Hardware Auto-Detect
    New hardware found: Wood Screw."
  • blackswan555
    blackswan555 Solar Expert Posts: 246 ✭✭
    I tried temp sensors on bat post and found that the heating from the charge source to the cables + post gave a very false reading compared to bat internal temp,
    At the start of charge, The post will heat a lot quicker than the internals and back your V off prematurely,
    New bit of (thin) double sided tape and on the outside of your warmest cell about half way up is my suggestion,
    Have a good one
    Tim
  • techntrek
    dwh wrote: »
    You forgot staples.
    Couldn't think of anything else witty, I was off my game that day. ;)
    Maybe your cables are not large enough, or have some crud at the interface ?
  • blackswan555
    mike90045 wrote: »
    New Rolls batteries, Rolls supplied interconnects, nuts/bolts/washers, All connections cleaned and greased on assembly, C10 charge current, Sensor placed on + internal terminal (Not on actual connection)
    Tim
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 6,746 ✭✭✭✭✭✭
    Tim
    I have never seen this on my system becasue I am solar and it heats up slower.
    My generator folks might see this but I doubt it. Have you tried another sensor?
    E-mail offgridsolar@sti.net
  • blackswan555
    No I did it as an experiment after reading somewhere the + bat post was a good place to put sensor, I confirmed results with OB temp sensor, IR digital thermometer, Glass thermometer and watching the temps and different results through wattplot, this is using charge currents up around the 200amp area though.
    Have a good one
    Tim
  • Dave Angelini
    I did not know outback made a sensor for the terminal? Xantrex makes both and they are very different BTW.
