PV Labels for Enphase system.
mr.radon
mr.radon Solar Expert Posts: 158 ✭✭✭✭✭
So what are the labels you have installed on your PV equipment?
I have a AC disconnect switch, Netmeter box, Service panel (PV system) and Main panel.
Any suggestions?
I'm putting these on the:
AC Disconnect labels:
(label 1)
PHOTOVOLTAIC AC SYSTEM DISCONNECT
Rated AC Output Current: 40AMPS
Rates AC Output Voltage: 240Volts
(label 2)
WARNING ELECTRIC SHOCK HAZARD
DO NOT TOUCH TERMINALS
TERMINALS ON BOTH LINE AND LOAD
SIDES MAY BE ENERGIZED
IN THE OPEN POSITION
Main Panel label:
(label 3)
INTERACTIVE PHOTOVOLTAIC
POWER CONNECTED
Service Panel label:
(label 4)
POWER CONNECTED
  • jcgee88
    jcgee88 Solar Expert Posts: 154 ✭✭
    Re: PV Labels for Enphase system.
    mr.radon wrote: »
    See attached photo...labels put on by my contractor.
    John
    Looks like the contractors next install will use a larger box !!
    mike90045 wrote: »
    i think he just needed to make the lettering smaller and trim the plastic to fit better. more work than he'd want though in doing that. those little machines that cut into the plastic are always at hamfests for amateur radio operators to get callsigns put on nametags. it makes me wonder if the guy moonlights on sundays at those hamfests.:confused:
  • jcgee88
    mike90045 wrote: »
    Actually, my cutoff box is itself redundant, and I'm guessing that
    Missouri will someday eliminate the requirement for one. That's
    what California has done already, as I understand. Which leads
    me to wonder....where do Californians put the labels?
    John
  • dwh
    I don't much like the idea of gluing those on. I would have used rivets.
  • mr.radon
    WA eliminated the AC disconnect switch for systems under 10KW with Enphase. If you have a single inverter they still require it (another reason to use Enphase).
    Mine is 10.125KW, so I'm stuck with an AC disconnect switch.
    The Utility only looks for the "AC disconnect switch" label. I'm sure the electrical inspector requires the others.
    My utility REQUIRES the labels be riveted to the panel(s). No stickers allowed.
    I made over 30KWhr today. I threw the switch till I get inspected.
  • dwh
    mr.radon wrote: »
    I was referring to the pic in jcgee88's post - his appear to have been glued on. Routed plastic placards, not stickers...but still glued on.
    Me no likey. Me likey rivets. Pop popitty pop pop.
  • drees
    drees Solar Expert Posts: 482 ✭✭✭
    mr.radon wrote: »
    Nice - you have the public link for monitoring data yet?
    FWIW - SDG&E here requires the AC disconnect, disconnect label, and a placard showing a simple line-diagram of the house/install near the service entrance. As a result, I have a huge 8"x11" red engraved placard (riveted) to my main service panel.
    Stickers were OK for the other labels. Sure would have been nice to not have needed the disconnect - would have simplified the wiring a small amount.
  • Galina
    Galina Registered Users Posts: 1
    I ordered my Labels from http://www.solarwarninglabels.net/ they have KIT For Inspection where you can find Everything, and there was one Card in which was explaining which label goes  where , Their prices are not bad as well
    Hope this Helped
