MC 4 Connectors
With54
Registered Users Posts: 21 ✭
Re: MC 4 Connectors
There are Y version of these connectors--But from a code point of view, you can only connect two strings in parallel.
More than two strings, then you need a combiner box any way.
Re: MC 4 ConnectorsAre these connectors designed for both SERIES and PARALLEL connections?
The tooling set to make your own is not too bad. I might have to order some for work to test them on a few machines.
http://www.amphenol-industrial.com/new/datasheet/IDS-17_Helios-H4.pdf
http://www.mouser.com/pdfdocs/Solarbrochure.pdf
http://www.newark.com/jsp/level5/module.jsp?moduleId=en_US/176240.xml
