12V cabin lighting.
I'm trying to set up a small 12V lighting system in an off-grid cabin. I want to have 3 or 4 LCD ceiling lights that will be used only 3 or 4 hours a day, 3 days a week during the summer. What I need to know is what wiring I use and if there is any other equipment I'll need (e.g. Low Voltage Disconnect?). Do I just connect the wiring from battery to the can normally? Thanks, Bill
Clarification: I'm going to solar charge the battery by itself (not enough sun near the cabin). I just need to know what goes between the battery and the LED lights.
  • CariboocootCariboocoot Banned Posts: 17,615 ✭✭
    Re: 12V cabin lighting.
    Voltage drop is a real issue with this sort of thing so ...
    http://forum.solar-electric.com/showthread.php?t=29
    (Voltage drop calculator.)
    I think you mean LED lights, not LCD. :p
    Fused circuit connected to the battery is fine. You could come off LVD terminals on a charge controller (if so equipped) but it isn't really necessary.
  • mike95490mike95490 Solar Expert Posts: 7,281 ✭✭✭✭
    Keep in mind, 1w of LED @ 12V is 1 amp, so size your wire accordingly.
    Check the manual for your charge controller, but 5-6A should be within the range of many controllers LVD's.
    1 LED fixture per ordinary household light switch is likely OK, but 5 or 6 amps worth, and the DC arc may wear them out early.
  • System2System2 Posts: 6,290 admin
    I did mean LED. Thanks. Where would I get a charge controller?
    billb wrote: »
    A good starting place would be the forum host, NAWS:
    http://store.solar-electric.com/chco.html
    :D
