Looking for Kaneka's new hybrid 110w PV's
papa
Solar Expert Posts: 51 ✭✭
Does anyone know of an verified, "IN STOCK" source for Kaneka's, recently released (Dec '09) 110w modules? I've been in the hunt since Feb and have unearth, at least, half-a-dozen sites touting "in stock". Three times I've bought and paid for these modules from 3 different sources, only to learn later (after my account was charged) that the requested PV's were either "not in stock" or there was a 4 to 6 week "lead time". Even the Morningstar MPPT controller I bought (and paid for) was said to be "back ordered".
I'm at wits end with this situation and any suggestions to a valid and reliable supplier would be greatly appreciated. I'm in So. Idaho so I'd prefer to avoid east coast suppliers due to increased shipping costs. Thank You
Re: Looking for Kaneka's new hybrid 110w PV's
They say there is a price war, and PV makers are starving, and warehouses are full, but try to buy and get something in hand, and it's delay, delay....Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Looking for Kaneka's new hybrid 110w PV'sThey say there is a price war, and PV makers are starving, and warehouses are full, but try to buy and get something in hand, and it's delay, delay....
This is the model of most installer/suppliers, let the stuff be drop shipped from some super warehouse. That way they get the latest price and don't have to stock inventory in a falling price market. -
Re: Looking for Kaneka's new hybrid 110w PV'sDoes anyone know of an verified, "IN STOCK" source for Kaneka's, recently released (Dec '09) 110w modules?
No, but would you be interested in 100W thin-film panels from Dupont? -
Re: Looking for Kaneka's new hybrid 110w PV'ssolar_dave wrote: »This is the model of most installer/suppliers, let the stuff be drop shipped from some super warehouse. That way they get the latest price and don't have to stock inventory in a falling price market.
Re: Looking for Kaneka's new hybrid 110w PV'sNo, but would you be interested in 100W thin-film panels from Dupont?
1. Voc is too high, my controller will only accommodate 75Voc
2. IIRC that supplier is in Florida... some 3000 miles from me. -
Re: Looking for Kaneka's new hybrid 110w PV'sAppreciate the suggestion - Two problems with the Dupont.
The Voc on the Kaneka's is over 80 volts according to some specs, but even the Kaneka site does not seem to have an official spec sheet. -
Initial values of 81Voc stabilised to 71Voc on the Kaneka's. Data sheet here:
http://download.solarshop.net/english/index.php?act=view&id=153 -
Re: Looking for Kaneka's new hybrid 110w PV'sThe Voc on the Kaneka's is over 80 volts according to some specs, but even the Kaneka site does not seem to have an official spec sheet.
http://www.pv.kaneka.co.jp/products/ -
The OP was asking about the new 110W hybrid panels. -
You can buy these from your pump manufacturer (grunfos I am guessing) for a generous markup! Look under their water pumping pages!"we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
Re: Looking for Kaneka's new hybrid 110w PV'sDave Sparks wrote: »You can buy these from your pump manufacturer (grunfos I am guessing) for a generous markup! Look under their water pumping pages!
PDF link here: http://www.us.grundfos.com/web/Download.nsf/b21d4b71af37dbe5082568a9000959ac/f022fa20b451057588256b7b005019ad?OpenDocument -
I just know that they use that make but maybe not that model. What pump do you have? The 125vdc mppt is near the sweet spot for the SQ flex."we go where power lines don't" Sierra Nevada mountain area
Re: Looking for Kaneka's new hybrid 110w PV'sDave Sparks wrote: »I just know that they use that make but maybe not that model. What pump do you have? The 125vdc mppt is near the sweet spot for the SQ flex.
To re-empathize, I planned this system around the Kaneka modules. The only other module which I considered and ultimately did purchase, was the older Sanyo HIP series. That (paid for) transaction got axed because the retailer tried to tack-on an additional $175 freight for a 900 mile distance. -
Also,...
Just last night, while module fishing, I spotted the new Sunforce CIGS 'Pro' model. Sadly, I have been unable to verify the specs - even Sunforces' down-loadable manual from their site doesn't state numbers, and the performance graphs are disturbingly illegible. Specs anyone? -
OK, so your not pumping then the most logical way to pick solar panels is to state what your system voltage will be. The most efficient way to make power is pick the sweet spot where there is enough voltage but not so much that the conversion loss stacks up. Good Luck and check the store here on the site!"we go where power lines don't" Sierra Nevada mountain area
Re: Looking for Kaneka's new hybrid 110w PV'sDave Sparks wrote: »OK, so your not pumping then the most logical way to pick solar panels is to state what your system voltage will be. The most efficient way to make power is pick the sweet spot where there is enough voltage but not so much that the conversion loss stacks up. Good Luck and check the store here on the site!
* Modules wired in parallel - if one module fails, the system is still fully functional, but at a lower amperage. In series strings, a single module loss renders the whole string useless - this is especially critical on small, lower wattage builds where cost and space constraints limit the total # of modules.
* Smaller gauge wires from PV-to-controller - cheaper, without inducing major system losses.
* The chosen MPPT controller allows up to 75Voc. From Morningstar:
"the greater the difference between the maximum power voltage and battery voltage, the greater the current boost. Current boost can be substantial in systems where the solar array is of a higher
nominal voltage than the battery" -
Re: Looking for Kaneka's new hybrid 110w PV's* Modules wired in parallel - if one module fails, the system is still fully functional, but at a lower amperage. In series strings, a single module loss renders the whole string useless - this is especially critical on small, lower wattage builds where cost and space constraints limit the total # of modules.
All crystalline modules have bypass diodes... So if a part of the panel fails, the bypass diode will cause the voltage to fall-but still allow current flow from the other series panels.
The diodes are needed anyway--each "cell" is only 0.5 volts and needs to be protected from reverse voltage/over current/shading.* Smaller gauge wires from PV-to-controller - cheaper, with no system losses.* The chosen MPPT controller allows up to 75Voc. From Morningstar:
Which controller are you looking at? The MorningStar MPPT 15 amp unit has a 75 Voc limit. (PDF)
The 45 and 60 amp units have Voc of 150 VDC. (PDF)
Re: Looking for Kaneka's new hybrid 110w PV'sAll crystalline modules have bypass diodes...
Because I am not as familiar with amorphous solar panels and how they wire their bypass diodes. Especially those very large ones intended for Grid Tied systems.
For smaller arrays (12 volt or so)--they can get by without any bypass diodes at all--as long as they are not series connected into higher voltage strings.
I am not a big fan of CIGS/Amorphous solar panels--so I have not paid much attention to how they wire their diodes (and, from what little I have seen--it is difficult to find much of anything at all about bypass/blocking diode wiring details for any large solar panels).
