Xantrex SW 2000 inverter aMPS?
Nomore
Nomore Registered Users Posts: 18 ✭✭
My uncle is looking for an inverter, I have read extensively here and I am considering the sw2000. He will only use it occasionally when there is a power outage and wants to be able to power his refrigerator. He keeps asking me how many amps this inverter is able to handle and I cannot find that info anywhere. If someone know would you mind sharing with me.
    Re: Xantrex SW 2000 inverter aMPS?
    now that is math as the continuous power is 2000w and the lowest voltage is 10.5v so 2000/10.5=190a. however, they recommend a 150a fuse so it will be that fuse as the limiting factor.
    http://www.xantrex.com/web/id/297/p/2733/pt/5/product.asp
  • mikeo
    mikeo Solar Expert Posts: 386 ✭✭✭
    If it is AC load he is asking about 2000 watts is 16 amps at 120 VAC.
  • Nomore
    mikeo wrote: »
    Thanks for the info, that is what I wanted to know.
