Kyocera doesn.t want us anymore
solarvic
solarvic Solar Expert Posts: 1,071 ✭✭✭✭
I just got an email from Wholesale Solar that Kyocera is limiting in USA its solar to comercial projects and very high volume intergrators. The rest of us will be left out. They said that some people that have projects planned will have to shift to other brands. Anyone else heard this yet? S:Dlarvic
  • Vic
    Re: Kyocera doesn.t want us anymore
    Hi solarvic,
    Bummer ! Have been teetering on the verge of ordering some Kyo 210's from the host of this site. This would not be good news, as it might raise the prices of other panels ...
    Thanks for the query. another Vic
  • solarvic
    There are other brands that are probably just as good. If I wanted the Kyocera panels I would try to get as many as I wanted to make sure I could complete the array I planned. If this is the truth I would think that the current supply will sell out fast. S:Dlarvic
  • joeaksa
    joeaksa Solar Expert Posts: 39
    Sad to see it happen.
    A question along this subject.
    Any rule of thumb about mixing panels between makers?
    As long as they are close to the same amp and voltage have thought that they could be mixed but never tried it.
    Basically, a good set of rules of thumb... Match parallel strings (one or more panels) Vmp to within 10%. And for series strings, match panels within 10%---Follow those rules, and you should be able to mix and match panels without problems.
    If you are paralleling panels on a PWM controller--Them Vmp should be >=~Vbatt-charging+2volts ... Any higher Vmp panels can be added (within the limits of controller input voltage/current) with the warning the higher Vmp is, the more losses that the PWM setup will lose (Vmp = 34 volts on a "12 volt" battery bank, will lose roughly 50% of the Vmp=34v panel's rated wattage).
    However, depending on voltage, current, and the number of panels/charge controllers you have--it can be very difficult to mix and match panels with wildly different Vmp/Imp ratings... Many times, it is simply easier to get a second charge controller and set the new panels up on that controller (PWM or MPPT as desired).
  • joeaksa
    Bill,
    Thanks and just came along some 75 watt panels for a good price. They are very close to the specs on my existing 80 watt panels and thought about tying them all together.
    Same thing that some of the Kyocera owners may be facing.
    Joe
    i wouldn't go off the handle yet with that news unless you can get it confirmed from other sources. this could hurt kyocera if it turns out to be false as many may switch to brands they would feel would still be around in planning their systems for. why would somebody feed false info (not implying you solarvic) as i can speculate a few possible reasons off the top of my head. kyocera's reputation and volume of business in the usa has been good and i do hope that this news turns out to be false. so far i have not found this report anywhere else other than wholesale solar in trying to confirm it.
    edit to add update:
    all i have found on kyocera so far has been this from kyocera "Kyocera will also meet strong demand in the solar energy business through expanded production capacity and sales channels."
    http://www.marketwatch.com/story/kyocera-announces-consolidated-financial-results-for-year-ended-march-31-2010-2010-04-27?reflink=MW_news_stmp
    nobody else is carrying the same news as wholesale solar indicates. expanded does not sound like cutting the individual sales out in the usa and i wonder if something's possibly up between kyocera and wholesale solar.:confused:
  • Photowhit
    BB. wrote: »
    I think your using the nominal voltage when you suggest losses of 50%.
    Charging voltage for a 24 volt system would be 28+ so 28/34=@80%, less for starting and finishing but not near the 50% mark..
  • solarvic
    Niel. I have 16 kyocera Kc 158g panels that all look like new and are the olderst ones I have. The quality is good and they will probably be still working way after I die. Got 12 sharps later and 2 of them don,t look like new anymore. I wouldn,t start a rumor but like you said there could be a problem between wholesale solar and kyocera. Last night I checked about 15 websites I have on my favorites list and a lot of them didn,t have any Kyocera panels listed or if they did they just had a small selection. I hope Kyocera didn,t take the GE aproach that they are big enough that they don,t need to want to deal with the small potato,s people with residential systems anymore. S:Dlarvic
    Photowhit wrote: »
    I was answering a "generic question" so I was comparing a "worst case/bad case" "generic 24 volt panel" on a "12 volt battery bank" with a PWM controller:
    • 14.4 volts charging / 17.5 volt Vmp panel = 0.82 charging eff.
    • 14.4 volts charging / 35 volt Vmp panel = 0.41 charging eff.
    There was no controller/panel panel information provided--So I was trying to make an example of a question that we frequently get around here ("24 volt panel" on 12 volt battery bank with a PWM controller).
    And we get the confusion of a "24 volt volt panel" and Voc vs Vmp ratings (a "24 volt panel" for a battery bank should have Vmp somewhere around 32-35 volts for proper charging of a 24 volt battery bank).
    Given the complexities of people's setups and the options in panels, controllers, battery bank voltages, local weather conditions--I usually suggest people ask about their system instead of generic questions--Because it becomes very difficult to write (and read) the generic answers with all of the caveats thrown in.
  • Photowhit
    Sorry, I misread...
  • bobdog
    bobdog Solar Expert Posts: 192 ✭✭
    solarvic wrote: »
    Maybe our gracious host can answer this? NAWS?
    Windsun (NAWS/Admin) has been working hard back at the shop and has not been able to spend as much time here as he would like...
    So, it may be a while before he can respond.
  • Vic
    Have been watching the $ on the Kyo 210 LPU at NAZW&S, as of this afternoon, seems the 20+ price has disappeared, and the Q1 price X 20 units yields about $1000-$1100 price increase in a lot of 20 ea, so there is quite possibly SOMETHING ot that "rumor".
    EDIT: And just now noticed that the Q20 price on SolarWorld 230's is missing and they, too, seem to have increased in price by about 50-or-so $$ per panel. Probably like rising interest rates, when the rise starts, brings folks out of the woodwork.
    Just one (or so) 'data point' or perhaps none at all. May have missed the price ebb.
    Vic
