mix and match panels
BB.
Super Moderators, Administrators Posts: 33,439 admin
We need to know the exact Vmp / Imp of the panels, and how they are configured (parallel, series, series/parallel) and what your battery bank voltage is.
In general, you match Vmp to Vmp within 10% for parallel connections, and match Imp to Imp within 10% for series connections... You will have relatively little power loss.
If you "match" panel voltage/currents way outside the 10% range, you can loose lots of power.
Re: mix and match panels
do know that the 10% figures mentioned are somewhat arbitrary as there is some loss within the 10% too. the closer to the current for series and the closer to the voltage for parallel the better and depends on what may be acceptable to a person. personally i feel 10% is too far out, but that's just me. -
Re: mix and match panelsdo know that the 10% figures mentioned are somewhat arbitrary as there is some loss within the 10% too. the closer to the current for series and the closer to the voltage for parallel the better and depends on what may be acceptable to a person. personally i feel 10% is too far out, but that's just me.
