DEKA Maintenance Saver Industrial and Xantrex XW settings
aj164
Solar Expert Posts: 122 ✭✭✭
I have a Xantrex XW 6048 and 1034A-H of Deka FLA "maintenance saver" industrial forklift-style batteries. (They are sold as 'solar', but are essentially the forklift batteries.)
We're doing OK with the generic FLA battery program in the XW inverter and charge controllers, but I'm wondering if we could do better with custom settings. These are lead-antimony plates, and the specific gravity at full charge is a bit lower than other types of FLA batteries.
With custom settings, I'm hoping to accomplish two things:
1) A more accurate battery meter on the XW System Control Panel.
2) A better charging profile and less chance of overcharging.
Also, once we get this figured out, I would like to have the settings preserved in this thread for others to reference.
Thanks,
AJ
Thanks,
AJ
Re: DEKA Maintenance Saver Industrial and Xantrex XW settings
You probably want to watch the specific gravity very closely and play with the absorb times... Forklift batteries have a higher self discharge rate than other types and so it is possible that as the batteries get old, that they could get into the 1-2% per day self discharge.
That, and watch your water levels. Too little water use (under charging) or too much (over charging) signify something needs to be improved with your charging/power usage.
Re: DEKA Maintenance Saver Industrial and Xantrex XW settingsI have a Xantrex XW 6048 and 1034A-H of Deka FLA "maintenance saver" industrial forklift-style batteries
I would simply call DEKA support and ask for the charging parameters. They have always been helpful to me with my battery charging questions -
This is the advice I received from DEKA:
(Batteries are 6-M100-23. 6 cell FLA lead-antimony, 1304A-H @ 20hr rate, four batteries in series for 48V nominal)
(PV array is 7.6kW -- no grid on site)
Bulk current max: 20% of 6 hour rate
Absorption: 2.4 - 2.45 vpc
Float: 2.3-2.35vpc
Equalize: 2.5 - 2.55vpc
Time in absorption should be 3-4 hours, not the 2 hours default XW setting. However, there is no specific recommended interval from engineering. "The required time in absorption changes as the battery ages and depending on how it is used."
"Float charging will not hurt these batteries."
"There is not a better battery anywhere."
"These batteries are meant to be worked." -
One more thing:
The Deka guidelines read "temperature coefficient: .005mV/ deg C". This is per cell, so 24 cells would be .120mV. I'm assuming this must be a typo, because .005mV is not much and not what I'm used to seeing for FLA batteries. I think they meant ".005 V/ deg C", which would be 120mV for 24 cells.
Also, I think there should be a minus in front of the number. Charging voltage normally should decrease with increasing temperature.
