Mounting Rails and Thermal Expansion
My aluminium mounting rails are going to be 40 feet long.
Should I worry about thermal expansion?
If yes, what would be the best/cheapest way to allow for it?
PS My rails stretch across a tilt-up structure, so their integrity is important. I don't want the rails to be able to be pulled apart.
  • drees
    drees Solar Expert Posts: 482 ✭✭✭
    Re: Mounting Rails and Thermal Expansion
    Use ProSolar RoofTrac rails with their rail splices which allow for thermal expansion/contraction when properly installed.
  • dancour
    dancour Registered Users Posts: 9
    Thanks for the tip: I found the info at:
    http://prosolar.com/PDFS/INSTALLpdf/ROOFTRAC_install.pdf
    but this type of expansion joint might pull apart in my application. I was wondering about a long slotted hole for the bolt - something like I use in woodworking.
  • drees
    Exactly how much movement do you expect in the rails in your application that they might separate?
