Any thoughts about 'low AC output' error on FX?
I keep getting a 'low AC output' error on my outback FX inverter when in invert mode. it immediately goes back to AC pass through mode and gives the error message. Any thoughts?
Re: Any thoughts about 'low AC output' error on FX?
from the fx manual:
"LOW AC OUTPUT VOLTAGE indicates that the inverter was not able to maintain adequate AC
output voltage (105 VAC or above) to power the loads connected. This is typically caused by the
load demanding more power than the inverter is able to deliver."
now if you aren't overloading the inverter this is an indication of something else wrong such as blown transistors. make sure it isn't overloaded. if it still does this with a smaller known load that it should handle then contact outback.
