I like the ribs on these
ws9876
Solar Expert Posts: 440 ✭✭✭
Re: I like the ribs on these
Wow - all those are in series. Is he going for steam production ? the losses from the hot pipe will be high.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I suspect he is heating that pool behind the collectors if so it is flowing at a real high volume so temp rise is probably not that great? -
best I have seen of this type.... It looks like the mirror plastic gets held in by the metal channel..nice and simple...
what kind of plastic do you think that is..?? -
His blog says pool heat - unfortunately the last post was August - hope he is OK
The blog is good also.
