12v batteries -need help on choosing them
edd_h
Registered Users Posts: 8 ✭
Hi
Ive recently been looking at a solar panel system, and am now looking at the batteries to buy for the system, and have found the following - they seem really cheap and good quality, can they be used / are they effective?
VARTA
SILVER dynamic
type I1
BATTERY
610 402 092
12V 110Ah 920A(en)
are they any good?
at the eqiverlant of 75 dollars a battery.
I've just found 10 on ebay uk for 380 sterling = 600dollars - really cheap!
VARTA
SILVER dynamic
type I1
BATTERY
610 402 092
12V 110Ah 920A(en)
are they any good?
Re: 12v batteries -need help on choosing them
According to this website, the are listed as a car battery.
From the sales brochure (large PDF download), I don't see anything that says they are designed for deep cycle application (is an AGM type battery).
Automotive batteries are typically designed for shallow discharge (15% or so discharge) and high current for starting and would not have very good life if use in a deep cycle application (solar power).
If your application only needed "small amounts" of power (15% discharge), but in larger surges, this battery may work for you.
My 2 cents, I do not know anything else about this battery line.
If this is in relation to the system that you've been proposing in other threads I'd say that you'll have an issue here of insufficient capacity (particularly if they are automotive batteries). Be aware that it's generally not advisable to parallel too many batteries, as you'll have issues with uneven charging and discharging. Usually most folks try to use only 1 or 2 parallel "sets" of batteries, for 12V system examples: 2 6V batteries in series, 4 6V batteries in series/parallel (two sets of two), 2 12V batteries in parallel, etc... Any more than 3 parallel sets and you're likely to have some problems, buying 10 of them would not be a good idea unless you were operating a 120V system (1 series string) or something. -
Better off scrapping the car battery idea and investing in something that at least says "Deep Cycle" on it. Amp hours can be within 10-15% of each other without charging problems, however, nothing beats the same hours. Gels are good batteries too if you can find them cheap enough.
How much power (wattage) do you wish to invest in Solar ?Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Lots of DIY Renewable Energy Projects on ETSY : Solar Panel builds, Wind Turbine builds, Rain Barrel build,etc. -
my comments in bold.GreenPowerManiac wrote: »Better off scrapping the car battery idea and investing in something that at least says "Deep Cycle" on it.
agreed.
i disagree with that statement as you should have the same battery make and model and near the same age and condition. you will have problems being off tolerance by 10-15%.
exactly, so buy the same new batteries. even new batteries of different makes with the same ah rating could charge/discharge differently enough to cause problems with each other.
gels may be slightly cheaper as they aren't as good as other types in their charge/discharge characteristics. they are a sealed battery, though, making them nonspillable and maintenance free.
- 299 In the Weeds--Member's Choice
