Decreased energy production
dhilldhill Posts: 47Solar Expert
Does heat decrease the production of energy in solar panels?
  • halfcrazyhalfcrazy Posts: 717Solar Expert ✭✭✭
    Re: Decreased energy production
    short answer is yes someone will chime in with the exact amount though. it is more then you would think for though.
  • crewzercrewzer Posts: 1,832Registered Users, Solar Expert ✭✭✭✭
    Yes. Check the "temperature coefficient of power" spec for your PV modules. A typical spec for polycrystalline modules is -0.5% per degree C. Translation: For every degree C of PV cell temp above 25 C, expect a ~0.5% drop in output power. Cell temp can run ~30 C above ambient in full "Sun", so a 12% to 15% drop in available power is not uncommon.
    HTH,
    Jim / crewzer
