Solargun's System
hii im new member
im designing pv system
capasity is 1 kw cells are 9 A ,1.2 volt and baterry is 12 volt 12 A
how i designing series and parallel connections and which volt values i can find
someone help me for this my question
thank you
thank you
Re: Solargun's System
Solargun,
I've split your post to create a new topic. Please tell us more about your system's components. As examples, is Kaneka the manufacturer of your PV modules? If so, what model? What controller are you planning to use? What type battery are your planning to use? What is your proposed battery system voltage?
More later...
Jim / crewzer
