Solar assisted golf-cart?
sunflexsolar
Registered Users Posts: 5 ✭
Hello all. I want to turn my father's Club Cart into a solar assisted Golf-Cart. My goal is to extend the range by about 30%, what do you think would be the perfect configuration? Has anyone done this? If so, could you give me some ideas as to what size panels you used/type of controller?
J Heath
(removed commercial link)
J Heath
Re: Solar assisted golf-cart?
I think you are just asking this so you can put your commercial link on this site.. like you have done on Solar Power Forumm and had it banned and removed.. -
For the cost and expense of adding glass panels and supports and their weight to the cart, maybe fresh batteries would work better. Adding 600W of solar (3 large panels) likely won't even gve you 30%Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
