How a 98%eff Inverter is built
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
An interesting article in Electronic Design, spills the secrets about building an inverter.
This is NOT a DIY or kit.
http://electronicdesign.com/Articles/ArticleID/21575/21575.html
excerpt:
Build An Efficient 500-W Solar-Power Inverter Using IGBTs
Combining optimized low- and high-side high-voltage IGBTs in a full-bridge topology, a dc-ac inverter uses a solar module to efficiently generate 500 W at 120-V/60-Hz single-phase ac output from 200-V dc input generated by a photovoltaic panel.
8 pages, and they do it without transformers, smoke or mirrors, just 2 smallish inductors
per fig #5, it's a sine output .
excerpt:
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: How a 98%eff Inverter is built
This is MSW design, you can easily get high efficiency with this. For true sine, it is much tougher.
GP -
per fig #5, it's a sine output.
They modulate a 20KHz signal to create the sine. It may mess your AM band up.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You're right. I missed the part that they use PIC controller to do PWM for the sine output. Wonder why the 600W true sine is still much more expensive than the MSW counterpart.
GP -
Most GT inverters are exactly this for the AC stage ... nothing new here
What this is missing is galvanic isolation and variable DC input. For example, the works ok for 120vac but you need 400 vdc for 240vac ... and no provisions for a variable input ( like 200-600vdc ).
The Xantrex GT for example is a buck converter to make the 600-190vdc a constant 190vdc, which then goes thru a 1:2 stepup ( h-bridge ) which takes care of the galvanic isolation and creation of the HV needed ( 400Vdc ) , the similar h-bridge for the DC to AC step
And it does all of this ( 3 conversion processes ) with about 4% total losses
Also Mosfets are substantially better than IGBT's even in the voltage class. I'd say the Xantrex DC-AC section is about 99% peak efficiency. -
Re: How a 98%eff Inverter is builtGreenerPower wrote: »Wonder why the 600W true sine is still much more expensive than the MSW counterpart.
GP
Sine is two steps, the up converter ( 12 to 200 vdc ) and then DC to AC conversion
MSW is just a direct step up ( H-bridge ) -
Re: How a 98%eff Inverter is builtSolar Guppy wrote: »Sine is two steps, the up converter ( 12 to 200 vdc ) and then DC to AC conversion
GP -
Yes, your missing the LC filter on the sine, in both cases the transformer is the voltage conversion , the sine then needs the smoothing transistion to make the 20-40khz a smooth voltage -
Re: How a 98%eff Inverter is builtSolar Guppy wrote: »Yes, your missing the LC filter on the sine, in both cases the transformer is the voltage conversion , the sine then needs the smoothing transistion to make the 20-40khz a smooth voltage
GP -
I am curious on the Outback (and apparently the XW series) if the low frequency silicon-iron transformer is fed directly with PWM waveform.
I saw pictures of the inside of the Outback FX inverter and I did not see any large PWM filter chokes. Can the low freq transformer somehow be used to remove the high frequency PWM component? -
Re: How a 98%eff Inverter is builtCan the low freq transformer somehow be used to remove the high frequency PWM component?
Thats what we do at work, it's called a choke. You plan the core material so it stops
responding at a desired frequency, and then the coil inductance attenuates the high
frequencies. The selected core couples the 60hz to the other winding.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
