inverter chargers & charge controllers
System Posts: 2,511 admin
Another newb question but I'm trying to put a system together from scratch.
I understand the need for a charge controller but I am perplexed as to the purpose of the charger unit in an inverter charger. Is this redundancy?
Martin
    BB. Super Moderators, Administrators Posts: 33,440 admin
    Re: inverter chargers & charge controllers
    You may end up with multiple charge controllers in a system...
    1. Solar Panel Charge Controller
    2. AC Backup Generator Charge Controller
    3. Wind Turbine Charge Controller
    4. Water Turbine Charge Controller
    5. Utility Mains AC Battery Charger (if Grid Tied).
    So--if your Inverter also has alternate inputs (AC Mains and/or Generator AC Input)--it will recharge your battery bank from those alternative AC Input sources.
    Think of a UPS (Uninterruptable Power Supply)--The AC Power (when available) charges the battery bank. When AC power fails, then the inverter switches over to DC power and "turns on" to supply off-grid AC power.
    The other power sources (solar, etc.) also need their own charge controllers that, in parallel, will recharge the battery bank.
    You can put charge controllers in parallel--without too many problems... The big issue is if one is programmed for a higher voltage (or running a equalize stage)--it will "take over" the battery load from the other chargers.
  • System2
    System2 Posts: 6,290 admin
    Thanks Bill, I hadn't thought of other charging mechanisms.
    Food for thought.
