connecting a solar array
This is very basic but I am doing some research so here goes:
I am looking a solar panels that use MC4 connectors and it appears to me that you can only connect them in series, +ve to -ve.
But I want to run a 12v system and connect a few panels in parellel. How do I do it or am I misunderstanding something?
Re: connecting a solar array
You use something like this:
http://store.solar-electric.com/mumc4colam.html -
Aha! Thanks for the help. -
If you're handy with a soldering gun, you could always cut the connnectors off, solder the wires together, and heatshrink the connection with some glue-lined waterproof tubing (or something similar). Not as elegant as the adapter method, but cheaper and probably more reliable.
Marc -
One reason to not cut the connector(s) off of the panels is that, for many vendors, it will invalidate the warranty.
Generally, if you only have a few connections to make up (and don't want to purchase the correct crimping tools)--just get a male/female cable from here, and cut them in half... Use those for your transition connections.
Re: connecting a solar arrayOne reason to not cut the connector(s) off of the panels is that, for many vendors, it will invalidate the warranty.
Sounds like a ploy to sell couplers
Marc -
Re: connecting a solar arraySounds like a ploy to sell couplers
Marc
Or a ploy to sell salvaged/returned material as new.
