2001 update
parbob1parbob1 Posts: 21Registered Users ✭✭
 Long story short build a house in the middle of the woods 2001 in the Northeast ...purchased SW 4024 inverter disconnect and battery pack charged by generator
. Sold the house and ended up getting it back in 2017. With every intention of installing solar panels. Inverter went bad  so solar panels will be moved to a 2019 project
what I have now 8- 6vt  235 batteries and a 6500 Honda generator  and disconnect/breaker.
What I’m shortly going to,purchase
Schneider SW4024 Inverter 120/240V
Schneider Conext System Control Panel
Schneider Conext Auto Start Control
12/24V Battery Vent Fan Control
am I missing anything, or making any mistakes
 SW Conext 4048
 AGS
Combox
16- 235 6V batteries
Honda 6500 gen
  • EstragonEstragon Posts: 2,838Registered Users ✭✭✭✭✭
    Missing loads? Maybe 24v makes sense,, or maybe 48v? 120/240v inverter suggests maybe some bigger loads that might be better at 48v?
    Off-grid.
  • mike95490mike95490 Posts: 7,901Solar Expert ✭✭✭✭
    edited September 29 #3
    I'd suggest getting the ComBox instead of the SCP - if you are able to connect a router and computer to it.   The SCP is lots of manual button pushing and scrolling. The combox lets you use a mouse and PC to do that, and see a bit more, install firmware updates  (or brick it if you do it wrong)
    With 8 batteries, wire in series and use a 48v system, not 24V
  • parbob1parbob1 Posts: 21Registered Users ✭✭
    Thank you I did not know Com box could replace scp. Is the com box windows or will apple work?..
     and I was mistaken I have 12 6vt 235 batteries.
    my old inverter was 24vt and supplied all power needs.
    With the new inverter producing 240v I was going to add 1/2 hp water pump
     SW Conext 4048
     AGS
    Combox
    Honda 6500 gen
    If the batteries are fairly new and in decent shape, I'd consider adding to get 2 strings at 48v. Keeps wire/connector sizes more reasonable, and less voltage sag on larger loads.
    Off-grid.
    So if I go 48v, can use my 250amp dc breaker box and 4/0 cable (10’)?
    Batteries are newer.
     SW Conext 4048
     AGS
    Combox
    Honda 6500 gen
    4/0 wire should be fine. You'd want to check the inverter spec/manual for max breaker size.
    Off-grid.
    Thank you for your help.  I think I’ll go with 48 v and the com box.
     SW Conext 4048
     AGS
    Combox
    Honda 6500 gen
  • MrM1MrM1 Posts: 277Registered Users ✭✭✭
    250amp  is spec for all of the SWs in the install guide on the Schneider web site.
    REC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array / MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware / OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system / Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2018 / System, Pics and Discussion
    The combox is a web interface, works with a browser, on my android or my win laptop.  Should work fine with a mac too
