Recommendation for float-service backup battery
jimmacphersonjimmacpherson Posts: 1Registered Users
Hi, I'd like a recommendation on specific makes / models of batteries for my long-term backup power needs for a fire/burglar alarm system.
Here are the specs & operating conditions:
12V, expected current draw max 2 to 3 Amps, only during power outages which occur ~3 times a year around these parts.
Desired capacity: 100+ amp-hours.
Charging: "dumb" constant trickle-charge from the alarm panel.
Manual cycling/maintenance: I can arrange to deep-cycle the battery manually at recommended intervals but cannot physically access the battery for fancier maintenance such as hydrometer / fluid-level checking, etc.
Physical conditions: protected, dry space with average temperature of 50ºF to 75ºF average, occasional seasonal extremes of 40º to 95ºF. No vibration or harsh chemical vapor exposure.)
I think what I'm looking for is a "telephone service backup battery," designed for constant standby with low trickle charge, infrequent and moderate discharge rates. I would like to optimize for the longest-possible service life. I.e. I would rather pay $500 for a battery that will last for 15 or 20 years, vs. paying $150 for a battery that lasts only 3 to 5 years.
  • stmarstmar Posts: 285Solar Expert ✭✭
    Lifeline is a good line, AGM so low maintenance. They are not cheap but very good quality.
  • mike95490mike95490 Posts: 7,902Solar Expert ✭✭✭✭
    Does the alarm company have any recomendations ?
    Otherwise, almost any group size 27 GEL battery should work for float, but I'd expect no more than 10 years out of it.
    15 years is not realistic.
  • EstragonEstragon Posts: 2,839Registered Users ✭✭✭✭✭
    Anyone have an opinion on using a lithium in this sort of application? Instead of floating, just charge it a couple times/year?
    Off-grid.
    Opinion - waste of money.  Unless you just order a batch of the Tadiran primary cells , 20 year lifetime
