xantrex freedom xc series inverter charger
bobiowabobiowa Posts: 3Registered Users
I cannot get my inverter to come on. It was working fine earlier. I did have my windshield replaced this afternoon in my sprinter and there are some electronics in it that need to be calibrated .....but I did not think the two items were related. The controller is working and the batteries have juice...any ideas?
  • mcgivormcgivor Posts: 2,211Solar Expert ✭✭✭✭✭
    Do the standard cold reboot, turn off switch, disconnect battery, wait 5 minutes, reconnect battery, turn on hopefully it will restore itself. This often solves problems, but not always, good luck. What inverter do you have?
  • bobiowabobiowa Posts: 3Registered Users
    thanks
    worked great thanks
