MS4448PAE not communicating with ME-RC50 or ME-BMK
SamOSamO Posts: 3Registered Users
I have a MS4448PAE installed with a ME-RC50 and a ME-BMK that will not communicate. I have 14.2 DCV on both cables coming from the inverter to the devices. When I connect the remote, and following the power up self-test, all of the LEDs turn off and “No Inverter Com” is displayed. Also, when the BMK sense module is powered up the LED ends up blinking red. I contacted Magnum Tech support and they we not very helpful. Thank you.
  • BB.BB. Posts: 27,907Super Moderators, Administrators admin
    Did you confirm the RJ cable is wired correctly and has good connections on all four positions?
    http://www.magnum-dimensions.com/sites/default/files/MagArchive/64-0003-Rev-F-ME-RC_Web.pdf (page 3 for cable)
  • SamOSamO Posts: 3Registered Users
    Thanks for your quick response. Yes I have -the very first thing I checked. I also checked several cables, too. Sam
  • EstragonEstragon Posts: 2,850Registered Users ✭✭✭✭✭
    It's easy to mix up rj ports, any chance the phone wire got plugged into the wrong port (eg battery temp sensor)?
    It's a bit surprising (to me at least), a data cable is running 14.2v. I would have expected ~5v, but I don't know much about Magnum networking.
    Off-grid.
    I understand. The ports are color coded fortunately. On this inverter there are 4 - RJ11 ports. According to the Magnum service engineer, the specs for the two inside ports, one for the remote and the other to monitor the batteries, are to be 12-15 VDC on the 2 inner pins.
    Maybe to run backlight. Oh well, sometimes it's worth checking the easy stuff first, sometimes not.
    Off-grid.
