solar heat
ws9876ws9876 Posts: 332Solar Expert ✭✭✭
I have a couple  windows on the SW side that get blasted by late day summer sun.They are thermopane but you can still feel the heat coming thru them. I covered one on the outside with plywood and that worked good. The other one is visible so I dont want to cover it outside. I put drapes on the inside but once the rays hit the glass there is still some heat that gets thru. Is there a good block I can put on the inside that will send the rays out again or is heat build up inevitable to some degree..??
  • EstragonEstragon Posts: 2,852Registered Users ✭✭✭✭✭
    Some folks use tinfoil. Not pretty, but it gets the job done.
    Off-grid.
    Another possibility, if feasable, would be to build an "eyebrow" over the SW windows, which would shade them in the high summer sun, but let lower fall/winter sun through.
    Off-grid.
  • mcgivormcgivor Posts: 2,222Solar Expert ✭✭✭✭✭
    Automotive window tint, good quality reflective type would minimize solar gain.
  • Raj174Raj174 Posts: 644Solar Expert ✭✭✭✭
    edited July 16 #5
    @ws9876
    I used a heat reflective film. Bought it at Home Depot. It works really well. If you get it, you'll need the application kit and window film application solution also. Link below is a sample, you may need a different size:
    https://www.homedepot.com/p/Gila-36-in-x-180-in-Titanium-Heat-Control-Window-Film-HRT361/100616385
    Rick
    3600W PV, MNE175DR-TR epanel modified, MN Classic 150, Outback Radian GS4048A, Mate3, 54.4V 207AH LiFePO4 no BMS, 4500W genset.
