Panel Mismatch due to breakage
tr0y
Solar Expert Posts: 99 ✭✭✭
Hey all -
I was wondering what, if any, real world issues would happen with a slight mismatch of one panel. They are the same size and type of silicon, different manufacturers. In a perfect world I would not do this, so please no scolding me. Just want real world thoughts.
The existing panel is
290W
Vmp 32.1v
Imp 9.05a
Voc 38.8v
Isc 9.58a
Panel I have easy access to is
275W
Vmp 31.5v
Imp 8.74a
Voc 38.6v
Isc 9.28a
Yes I know I will be brought to the lowest common denominator, but they seem close enough ???
290W
Vmp 32.1v
Imp 9.05a
Voc 38.8v
Isc 9.58a
275W
Vmp 31.5v
Imp 8.74a
Voc 38.6v
Isc 9.28a
Yes, they should be close enough... If Vmp and Imp between the two panels is within 5%, that is pretty close to "identical".
If the two panels are within 10% for Vmp/Imp, they will still work OK.
In general, match Vmp for parallel connections (or Vmp-strings for multi-panel strings) or match Imp for series connected panels.
