I have a solar energy job interview in the following days
ahmedzeinahmedzein Posts: 4Registered Users
edited July 11 in Solar Beginners Corner #1
I have been to the last stage which is the technical interview ,and i have known from a friend in this company that the interview will focus mainly on the electrical side of the pv .
I need to know what kind of questions will i be asked regarding the electricity because I am a mechanical engineer and my electric information are just fundamental.So if anyone could help with some topics to read or the kind of questions that will be asked i will be very grateful .
Thanks in advance
  • PhotowhitPhotowhit Posts: 4,605Solar Expert ✭✭✭✭
    Just admit to what you don't know, honesty is what an employer will be looking for, and need.
    I suspect there will be someone who has a strong technical knowledge to run the jobs.
    If it's for small residential installations, might make your self aware of the differences between micro-inverters and String inverters(I used this as I lack the knowledge of a better term)
  • BB.BB. Posts: 27,566Super Moderators admin
    This is a thread were we put a lot of "interesting facts" and links for solar power... Take a quick look through and read some of the details.
    http://forum.solar-electric.com/discussion/4426/working-thread-for-solar-beginner-post-faq/p1
    The basic electrical formulas work just fine for most solar questions;
    http://www.sengpielaudio.com/calculator-ohm.htm
    They can all be derived from circuit theory and calculas -- But the basics will serve you well:
    Volts = Current * Resistance
    Power = V*I = V^2 / R = I^2 * R
    And such.
  • EstragonEstragon Posts: 2,444Registered Users ✭✭✭✭
    It would help to know what kind of job in the solar industry.
    As an example, the correct answer in the technical interview for a sales-related automotive job is "I like money". You simply need to demonstrate confidence in your ability to use technical knowledge to the extent necessary to further that goal. A grasp of technical details without demonstrating an ability to convert it into profitable sales would be a fail.
    If it's more of a technical role, my guess is they'll know a mechanical engineer doesn't know a lot about EE generally or solar in particular. In that case, @Photowhit is right, don't try to fake it. Get a basic grasp on things (eg from Bill's links) so you can show adaptibility and an interest in learning outside your area of expertise.
    Off-grid.
