Off Grid Motor Help
evenwizevenwiz Posts: 3Registered Users
edited June 17 in Solar Beginners Corner #1
Hello everyone. First off I am not familiar with off grid solar other than knowing I need certain critical components. Will appreciate if someone can guide me. :smiley:
I am trying to get a 15Vdc, 1A motor working by attaching to a solar panel with a charge controller and battery. The motor will not be operating 24/7. It will only be turned on 2-3 times per hour a day and it's operation duration around 2-5minutes only. The problem I am having is knowing what should be the specifications for the three components to power this fellow.
Will appreciate if someone can help me out here! Thank you!
  • mcgivormcgivor Posts: 2,164Solar Expert ✭✭✭✭✭
    Will the motor be needed only during the day?
  • evenwizevenwiz Posts: 3Registered Users
    edited June 17 #3
    Yes, only use during the day. Forget to mention that the motor is to power the window blinds. The motor has an on/off switch on its own.
    edited June 17 #4
    Reason I asked was it could be powered directly by a panel without needing a controller or battery, but it would be better with a battery, given the use
    The calculation below is assuming  maximum useage.
    3 times for 5 minutes per hour for 12 hours would be 180 minutes total or 3 hours
    3 hours × 1 amp = 3 ampere-hours  (Ah)
    Battery capacity needs to be greater than maximum useage by at least 50% so 6Ah minimum 10A better
    PV module or panel wise a 30 to 40 watt one would be in the ballpark to maintain the battery
    A cheap 5/10 amp PWM controller would be fine for this very small system
    This would be a system where the solar does most of the work during a sunny day, providing battery backup should there be limited or no sun.
    Thank you mcgivor! I will headstart from here and try it out. :D
