Lightning strikes again? Morningstar TS 60
mcgivormcgivor Posts: 1,746Registered Users ✭✭✭✭
Yesterday there was a violent storm which passed through, major lightning, I was not at home so shutting down wasn't an option, but could see the storm move in from where I was 4Km to the south, was on a tractor so no chance of racing home. When I got home the smell of magic smoke filled the room where the controller, Morningstar TS 60, is located, can't say 100% if lightning was the cause but too coincidental to be anything else. The component(s) that vaporized appear th be the diode(s) nearest the solar input positive terminal, SPD didn't help and appears fine?, everything else in the system still functional, the controller was indicating over voltage shutdown, red/green Led's alternating, remote meter blank but still functional with replacement unit,  had a spare on hand, so 30 minutes to get up and running. Last time the inverter got surged and falied, ironically a year ago, May 2017.
  • EstragonEstragon Posts: 2,310Registered Users ✭✭✭✭
    Struck by lightning twice in a year? Ugh! Would a lightning rod help?
    Off-grid.
  • westbranchwestbranch Posts: 5,023Solar Expert ✭✭✭✭
     Where is the one you have positioned in the wiring ? Do you have more than 1 SPD?
    West Chilcotin, BC, Canada
  • PhotowhitPhotowhit Posts: 4,529Solar Expert ✭✭✭✭
    It might hurt! My understanding is most damage from lightning strikes are near misses that come in from the grounding of the system. Likely a direct hit would do some damage outside of the power center...
  • mike95490mike95490 Posts: 7,642Solar Expert ✭✭✭✭
    That's a lot of smoke for a diode. Or it was a very large diode.  I'd consider it all toast.  Expect other electronics to be weakened and about to fail.
    Just as a matter of interest, are the big zig-zaggy things how the CC transfers heat to the external heat sink fins?
    If so, maybe a lower resistance path to ground? Having gone miles, I'm sure lightning does what it wants, but maybe that's a tasty target. It would also avoid a SPD on the DC wiring that way?
    Off-grid.
  • mcgivormcgivor Posts: 1,746Registered Users ✭✭✭✭
    edited May 30 #8
    SPD wise, DC, one at incoming solar disconnect, downstream side, AC, main live bus.
    Lighting rod? Do have a mast with an air terminal, was hit 4 days after installing, took out the inverter no SPD at that time.
    The zigzag thing is an aluminum bar with a stainless steel spring, under which is a plastic piece with fingers that pass through the PCB appling pressure to the mosfets against the heat sink , the 3 screws thread into the heat sink.
    Bad luck perhaps, the mast is intended to offer a path to ground other than a structure, dose it contribute to the damage caused, who knows, my understanding is that if lightning is going to strike in the area the point of contact is generally concluded at the last micro second so the mast offers a path of least resistance.
    Bad luck perhaps ...
    Since you and your family are still here to tell the tale, I guess it depends how you define bad luck :wink:
    Sometimes bad stuff happens to good people. It just is.
    Off-grid.
  • Dave AngeliniDave Angelini Posts: 3,689Solar Expert ✭✭✭✭
    Reasoning with lightning can be as reasoning with hurricanes (cyclones)  :'(
    E-mail [email protected]
    edited May 30 #11
    Out of curiosity I made contact with tech support including images, asking what they thought the cause of failure might be, without furnishing any details, emphasis on no warranty claim despite being within warranty. The response was. The damage to D3 is consistent  with a high voltage transient, was lightning present in the area? Naturally I answered honestly that it was likely and that I was just interested in their opinion.
    Looks like it to me.... Only crazy people would give warranty for that!
    I once visited a boat that was hit and in the day all the lighting was incandescent.
    Every light bulb exploded and there was glass everywhere. You can imagine what the inside of electronics looked like.
    They lost 3 garmin gps units. they were over 1,500 us dollars then.
