advice on inverter/charger
wastwast Posts: 41Registered Users ✭✭
any recommendation on a 1000 or 1500 watt pure sine wave 24 volt inverter charger for a reasonable price..
  • EstragonEstragon Posts: 2,629Registered Users ✭✭✭✭
    In that size range, you may want to consider separate inverter and charger.
    Samlex inverters seem to be well regarded on the forum. Charger would depends on your needs. I went with a pair of relative inexpensive Iotas on my 12v system as I charge that bank almost entirely with solar and only rarely for bulk charging with generator. Other applications may need 3-stage, power factor corrected, etc., charging.
    Off-grid.
  • mcgivormcgivor Posts: 2,065Solar Expert ✭✭✭✭
    It would seem there are very few to no pure sine wave inverter chargers below 2000W, only modified sine wave.
  • ThomThom Posts: 180Solar Expert ✭✭✭
    I just use 2 BD smart 10a car chargers. Only need them a few times in Dec Jan . My battery bank is 7 years old.
    Thom
    Off grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator
  • wastwast Posts: 41Registered Users ✭✭
    anyone familiar with eliminator> they make a 1000 watt pure sine wave inverter
    Eliminator is a brand sold by Canadian Tire, if I'm not mistaken, usually 12V and not an inverter charger for 24V, is this the reference?
    yea u are correct only 12 volt... and not a charger.. may go the inverter and separate charger route..
  • BB.BB. Posts: 27,699Super Moderators admin
