wiring from panels to charge controller to batteries
wastwast Posts: 41Registered Users ✭✭
what is correct way to wire 2 panels in series and to controller and on to batteries..do I need breakers in between somewhere
  • EstragonEstragon Posts: 2,840Registered Users ✭✭✭✭✭
    Simple answer is yes.
    Off-grid.
  • littleharbor2littleharbor2 Posts: 1,027Solar Expert ✭✭✭✭
    edited May 22 #3
    Definitely need a fuse at the battery rated for the wire size you're using. As far as breakers you need nothing for a single string of panels. That being said you might want to add a small breaker box for convenience when doing system maintenance. Bad pic sorry. Old stuff.
