Grundfos level switch
zozomikezozomike Posts: 87Solar Expert ✭✭✭
So....12  years ago I put in my Grundfos sqflex11 from our host.( good life on our water so hard we should lay bricks with it)  At the time I bought the level switch, this one, and never installed. Now changing my system, and pulled it off the shelf as I will want a level switch with the new setup. And Darn, cannot figure out the depth to set the thing. Have used an Ohm meter, does not seem to switch till near vertical. Anyone used this as a tank fill and how deep in the tank did you put the switch?
Grundfos Low-Level Float Switch for CU-200
Off grid, all solar, passive and active ( winter wood heat supplements) solar DHW, no backup.
Array 1 1980w,   12 Solarworld 165 w panels - Outback Flex max 80
Array 2 1590 w, 6 Solarworld 265 w panels - Outback flex max 60
Well array 600w, 6 Kyocera 130 w  with Grundfos sqflex11 and cu200 to elevated  storage, ( 2- 330 g tanks,) no battery storage at well
GB industrial 510 AH battery 24 V
Outback VFX 3525 inverter,
  • mike95490mike95490 Posts: 7,868Solar Expert ✭✭✭✭
    Looks a lot like the float switch in my tank.  My switch has a big off-center weight in it, as you tilt it (as if it was floating on surface, or dangling straight down), you can feel and hear a big "clunk" as the element switches.
    My switch is quite near the top of the tank
  • BB.BB. Posts: 27,776Super Moderators admin
    You put a clamp to the wire about 1 foot from the float.... As the water level rises, the float rises (with cord end down) and "turns off".
    As water level falls, the float sinks (with cord end up). And switch turns on.
    You may have to have the pivot point below the water level (to get enough motion on the switch to reliable turn on/off).
    httpwwwthepumpwarehousecomimagesproductsSJEPumpmaster_1000PXjpg
    Make sure that the area where you mount the float does not have a wall, piping, or other stuff that can interfere with the switch--Or the pump will not cycle correctly (as my sump pump failed to turn on and my furnace flooded because the sump was too small for pump+float switch to operate freely)).
  • zozomikezozomike Posts: 87Solar Expert ✭✭✭
    Thanks guys, I guess I will just try it like Bill suggested.
