Solar System Switches
Pete4049
Pete4049 Registered Users Posts: 4
Should I install a switch in the cable leading from my battery bank to the inverter.  What is the switch protecting?  The cable or the inverter or both?  Should there be a switch in the cable between the charge controller & the battery bank?  Do I need both switches?  Thanks, Pete
  • 706jim
    706jim Solar Expert Posts: 514 ✭✭✭✭
    Or a high capacity circuit breaker. There's nothing quite like the surprise of a high amperage short circuit and you have no way of disconnecting it.
    Think "Fire".
    Island cottage solar system with 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter, Outback Flexmax 80 MPPT charge controller 8 Trojan L16's. Insignia 11.5 cubic foot electric fridge. My 30th year.
  • mcgivor
    edited May 2018 #3
    Installing DC rated circuit breakers in both positions, sized appropriately to protect the conductors feeding the inverter /battery, will not only provide a convenient service disconnect but also protect the conductors in the event of a short circuit. Batteries can supply enormous amounts of current which should never be underestimated, a fused disconnect, or fuse plus disconnect could bu used but must be DC rated for the appropriate voltage / current, but cost wise breakers tend to be the more economical in the long run as a blown fuse needs replacing, whereas a breaker would require resetting. The purpose of overcurrent protection is to protect the conductors not the device fed by the conductors.
