PV to Inverter fuses & or breakers
Pete4049
Pete4049 Registered Users Posts: 4
Do I need protect negative wiring between PVs & inverter with a fuse or breaker?.  Should the GFP on positive wiring between PVs & inverter be placed ahead of or after the breaker?  Thanks
  • Estragon
    Negative typically isn't fused (assuming negative ground system). Some charge controllers (eg Midnite classic) have GFP built in. If not, between the pv breaker and the charge controller I think.
    Off-grid.
    BB. Super Moderators, Administrators Posts: 33,443 admin
    Can you tell us more about your system, any components you have purchased our are thinking about purchasing?
    Is this in a vehicle, cabin, or other? DC loads and\or or AC inverter?
    Grounding is a complex subject. If done wrong, it can be worse than doing a half way job.
    Bill
