Absorb time
CgarnerCgarner Posts: 2Registered Users
I have a system that is less than one year old off grid.  My battery shuts off only after one hour of  use.  I have 9 panels, 285 wats, outback flexpower 120 Volt.  4 outback 12v batteries sealed.  it is set to 1 hr absorb time.  If I change my absorb time to 2 hours do you think it will help my issue
  • westbranchwestbranch Posts: 5,087Solar Expert ✭✭✭✭
    edited March 27 #2
    What is the Manufacturers recommended time for  ABSORB?  Is your charger using a BTS or RTS ?  and YES if you are in the northern part of the world, the longer ABSORB time should help long term but you may already have damaged your batteries with only 1 Hr  of  ABSORB
    .It is better if you post all the charging parameters rather than one part at a time as there may be other factors involved, rather than guessing...
    West Chilcotin, BC, Canada
  • EstragonEstragon Posts: 2,770Registered Users ✭✭✭✭
    It's also helpful to start a single post/thread for a single issue. Multiple threads tend to confuse things.
    Off-grid.
  • BB.BB. Posts: 27,788Super Moderators admin
    I will close this thread so the discussion can continue in the other thread... Carry on over here:
    http://forum.solar-electric.com/discussion/353136/customer#latest
    Unfortunately, with this forum software, I cannot merge threads/discussions.
This discussion has been closed.
