Q: Why would you want to allow your wind turbine to free spin?
fooliosfoolios Posts: 53Solar Expert ✭✭
Looking up brake info, I see options on the brakes.
Why would free spin be an option? I read free spin happens when loads are missing and the battery is overvoltage; which could result in the destruction of the turbine.
Switch Positions:
  • Up -- Turbine is connected to the battery or rectifier. (Switch is closed)
  • Middle -- Turbine is fully disconnected, free spinning.
  • Down -- Turbine wires are shorted together. Brake is on.
  • EstragonEstragon Posts: 2,310Registered Users ✭✭✭✭
    Maybe so you can work on it with circuits open, check to make sure it spins with no load, etc?
    Off-grid.
  • mcgivormcgivor Posts: 1,747Registered Users ✭✭✭✭
    Kind of what I was thinking, a neutral gear of sorts, to test the bearings without load or brake.
  • fooliosfoolios Posts: 53Solar Expert ✭✭
    Excellent.
    Thanks.
  • BB.BB. Posts: 27,432Super Moderators admin
    A lot of double pole double throw switch have a middle position where they are off...
    Bill
