Looking for some batteries that are available here in Central America
mevenable
Registered Users Posts: 72 ✭✭
I am thinking to get rid of my NC106 from Outback, which are not doing well at all after 3.5 months, and the best alternative I have found so far is Deka Promaster DC 12 V 155 AH C20. Does anyone have an opinion on this? Will these work for some heavy loads during the day (somewhat over panel capacity)? I know that even 4 at this capacity will handle my needs at night, and will easily be charged by my panels even on a cloudy day
IMHO, you would be better off going with a string of 6v golf cart (~225ah) or L16 (~350ah) flooded. The higher capacity would handle larger surge loads better, and all else held equal, will have lower depth of discharge and longer life.Off-grid.
Second the golf cart batteries, especially flooded for their forgiveness, robustness and reliability. I'm assuming Nicaragua based on the latitude of 12° stated in your other thread, here is a link to a Trojan distributor.
http://ecami.com.ni/catalog/
