Solar Panel Setup for a Fahrenheat FUH54 240-volt Garage Heater, 2500-5000-watt
gwpguygwpguy Posts: 1Registered Users
I am extremely new to the Solar energy technology.   So excuse me in advance for my lack of knowledge.
I am considering buying this heater for my garage.   I am contemplating using solar to help keep the energy costs down.   I don't even know where to start.    What size panels?  Batteries? Inverter?  This would not be on 24 x 7.   Probably just on the weekend while I am in the garage and a few nights out of the week.   Any insights you can give me would be greatly appreciated.
Here are the specs on the heater.
https://www.marleymep.com/system/files/node/file/field-file//5200-11195-000.pdf
  • NANOcontrolNANOcontrol Posts: 47Registered Users ✭✭
    How may panels are you thinking about buying??????  I consider that heater undesirable as it requires a fan.  Best performance would be from baseboard heaters with natural convection.  A guy on youtube has a liquid floor heating system for his garage using a hot water tank and pump.  That would provide some storage for the weekend.  If using an inverter, that is delusional.  A pulsed DC system is the best for resistive heating. I heat all my hot water with PV solar which is now cheaper than direct solar.  No one here has more experience heating with PV and given that all the electronics is custom it seems you will have little success with this idea.
  • PhotowhitPhotowhit Posts: 4,532Solar Expert ✭✭✭✭
    Solar will almost always be more expensive than grid energy. Even in spots where it can be cost effective, solar energy is much more costly when you don't have even energy use profile as the sun's energy is spread somewhat evenly in daily doses and using it only on weekends requires larger storage.
  • oil pan 4oil pan 4 Posts: 669Solar Expert ✭✭✭✭
    You do realize it's almost always cheaper to save power than it is to generate it right?
    So instead of buying that piece of crap electrical resistance heater, maybe put in a good mini split heat pump?
    You get 3 or 4 times the heat for the same amount of electrical power used.
    Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
    Solar roof top GMC suburban, a normal 3/4 ton suburban with 180 watts of panels on the roof and 10 amp genasun MPPT, 2000w samlex pure sine wave inverter, 12v gast and ARB air compressors.
