Amazon is now peddling a 100 watt system...
softdownsoftdown Posts: 1,800Solar Expert ✭✭✭✭
4.1 stars? Not bad considering all the possible mistakes that purchasers are likely to make. Would be nice for camping etc.
https://www.amazon.com/dp/B06XWL79L7?ref_=pfb_53h352c6h1413kf52h13m8d05f6c&tag=hydfbook0e-20&ascsubtag=pfb-P11-V01-O3-rqx99r-RR71TD
  • HorseflyHorsefly Posts: 301Registered Users ✭✭✭
    Let me introduce you to Fakespot.com.  Amazon and it's accompanying review database have become such a huge force, there is now a undercurrent market to do "fake" reviews and ratings. Fakespot uses an AI engine to look at the reviews and make a qualitative judgement as to the overall trustworthiness of those reviews. In this case, lots of them are considered fake.
    https://www.fakespot.com/product/hqst-100-watt-12volt-off-grid-polycrystalline-portable-foldable-solar-panel-suitcase-with-charge-controller
    Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 4 x Vmax XTR12-155 12V, 155AH batteries in a 2x2 24V 310AH bank.
  • softdownsoftdown Posts: 1,800Solar Expert ✭✭✭✭
    Fakespot seems pretty cool. Soon the spoofers will be able to fool Fakespot though, this will likely be cat and mouse.
    "Our engine has profiled the reviewer patterns and has determined that there is minimal deception involved."
    A huge problem with reviews is that they are done quickly after the purchase. It would be interesting to find what the consumer thinks a few years later.
    I grew up with unlimited lifetime warranties....some of them transferable. 30 days is pretty common now. It can take me 30 days to unwrap a package. I go the post office every two weeks.
  • oil pan 4oil pan 4 Posts: 669Solar Expert ✭✭✭✭
    Or could be the people have no idea hat they are buying.
    IMO a decent charge controller should cost most of the  $200, because with something that small you will need to have MPPT.
    Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
    Solar roof top GMC suburban, a normal 3/4 ton suburban with 180 watts of panels on the roof and 10 amp genasun MPPT, 2000w samlex pure sine wave inverter, 12v gast and ARB air compressors.
  • PhotowhitPhotowhit Posts: 4,480Solar Expert ✭✭✭✭
    Pretty much totally disagree, there is no reason to spend money on a MPPT type charge controller to gain maybe 10%, particularly on a 100 watt 12 volt nominal panel....
    FWIW - This is NOT being sold by Amazon, It is in Amazon's market place and they will have to follow Amazon's rules, and you will have Amazon backing it up as it's fulfilled by Amazon, but it is being sold by HQSTSolar
    There's a clue where it says  "Sold by HQSTSolar and Fulfilled by Amazon."
  • EstragonEstragon Posts: 2,218Registered Users ✭✭✭✭
    It really depends on the applcation. IMHO, pwm makes more sense where panel(s) will be close to the controller and/or wired in parallel. In applications where an array is further away, higher voltage series wiring and mppt makes more sense. Use the right tool for the job.
    Off-grid.
    Okay, in this application a single 100watt panel (or a wired pair) with a Vmp of 17.8. An MPPT charge controller has NO part in the discussion.
    True.
    Off-grid.
