Battery fan won't run on battery bank USB, but will on 'puter USB... Any Ideas for lite bike elec?
PhotowhitPhotowhit Posts: 4,483Solar Expert ✭✭✭✭
I've been contemplating setting up a bicycle travel, small solar system, using a lithium battery bank as the battery bank.
I've picked up a few odds and ends to this end, and last night I wired a small 5" battery fan with a USB cords and plugged it into my computer and it worked fine. Later I tried my battery bank and it won't run...
I had used red and the bare ground wire.
After checking a color wiring pinout I went ahead and attached the black to the bare ground and it worked.
Curios why this happened? I guess the outside metal is wired on the computer, but not the battery bank? Just seems odd.
Can I leave it this way, or should I disconnect the bare ground?
Guess I should say, Mine was a thrift store find and didn't come with the usb cord, I just hard wired to the 4 - AA battery slot.
Open to other interesting electronic devices to add to the bicycle dashboard. maybe a small TV, I'll use a Sandisk sport for radio and mp3 player and a raspberry Pi zero for a computer. Looking for a small computer screen or a hack for a small high res picture display or some other monitor. Glad to hear ideas.
  • EstragonEstragon Posts: 2,226Registered Users ✭✭✭✭
    Maybe it's just me, but I find the labelling on the pic a bit confusing. It seems to me a serial (uSb) cable minimally has receive-rx, transmit-tx, and signal ground. The signal ground is the reference for high/low signal voltage.
    It can/should be at about the same potential as the DC negative, but as it's important as the signal reference, generally a separate wire AFAIK. The bare ground is apparently the DC negative?
    There are small screens available for rPi, but I'm not sure about the zero. Maybe use a phone ssh app for kb/display?
    Off-grid.
  • just startingjust starting Posts: 203Registered Users ✭✭
    edited March 8 #3
    One of these
    1500 w PV- xantrex 60-150 mppt -894 ah agm- Rd2824 magnum MSW inverter- 250 E panel-  chest freezer to fridge- Samlex PST 1524 - fl Samsung wf5200 washer Ryobi 2200 watt gen-80 w panel with morningstar sunguard 4.5- 2 gc2- for water pump 5.5 GPM 60 psi - 24v 5.5 gmp 60psi water pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher with the heayer disconnected and 168 degree water.
    And they make touch screens for the raspberry pi depending on how much you want to spend a cool case with a 3.5 screen is about 35$
