KID update froze
ws9876
Solar Expert Posts: 440 ✭✭✭
I tried to do an update on the KID firmware. I verified that I was on 12 volt and it saved it. Then I dragged the new firmware file into the pop up box but the screen had broken up text on it and them it said firware 2.2 Bad Firmware..... and I cant get out to the main menu. Its stuck
on this screen. I disconnected the battery and reconnected but I still cant get out of the screen. I took the back off and I notice that there is a small hard reset button ...should I hit it??
solved.... I had to extract the files before it took them in Ubuntu....then it worked but it takes a few seconds to react and start..
OK ws.., Good that you have solved the issue.
The KID is a neat, medium-sized MPPT CC. Have fun with it, Vic
Off Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
