Do I need a conduit for out door wiring?
Do I need a conduit for my wire from the solar panels to the inverter on the wall outside? If needed then what type, pvc or metal conduit is best for 1000watt?
  • mike95490mike95490 Posts: 7,564Solar Expert ✭✭✭✭
    If the wire is exposed, tweakers in your area become attracted to it, and steal it to sell for drugs.
  • cow_ranchercow_rancher Posts: 77Solar Expert ✭✭✭
    You can buy direct burial wire... around here the gophers didn't get the NEC memo that said it was OK.
    Rancher
  • Raj174Raj174 Posts: 581Solar Expert ✭✭✭✭
    I would use electrical PVC. It's fairly easy to measure, cut and fit together. It protects the wiring from solar UV and critters.
    Rick
    12 x 300W Renogy PV, MNE175DR-TR epanel modified, MN Classic 150, Outback Radian GS4048A, Mate3, 54.4V 207AH HI Power LiFePO4 no BMS, 4000W gen.
  • mcgivormcgivor Posts: 1,548Registered Users ✭✭✭✭
    Advantages, disadvantages, PVC cheap and easy, Steel offers more mechanical protection, including lightning protection, but at the expense of installation cost, method 3, Teck cable, all conductors including ground, no connectors, metallic protection easy installation, really the best of both worlds, consider aluminum to save even more.
  • dennis461dennis461 Posts: 100Registered Users ✭✭
    PVC looks like crap after two years in direct sunlight.
    Camden County, NJ, USA
    19 SW285 panels
    SE5000 inverter
    grid tied
  • PhotowhitPhotowhit Posts: 4,450Solar Expert ✭✭✭✭
    The answer to your question is NO, you do not need to use conduit unless it is locally required. You can use USE2 or 'solar wire' and be okay with NEC code. These wires are resistant to deterioration from direct sunlight. It would look better and be better protected in conduit.
    Rancher
    Somehow I was thinking he was going to bury it, ...never mind...
    Rancher
