Divert Plumbing Vents on Roof (Solution)
JacobVargasJacobVargas Posts: 1Registered Users, Users Awaiting Email Confirmation
Finally found a solution to divert those vent pipes.  They're always taking up space in which extra panels could be, such a waste.
Code changes now allow for a product called Solar Roof Jack to Divert.   Haven't had any problems with inspectors and they all give instant approval.
www.SolarRoofJack.com
  • mike95490mike95490 Posts: 7,783Solar Expert ✭✭✭✭
    The roof vents are often the easiest way for a plumber with a snake to clear a clog.  Most houses don't have clean-out plugs, and if you can't snake through a roof vent, you have to open lines up under a sink - messy and stinky.
  • DanS26DanS26 Posts: 235Solar Expert ✭✭✭
    I'd like to hear from the plumbing experts about having vent pipes lay horizontally in freezing weather conditions.  Especially long horizontal runs.
    18.2kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro System monitoring with PVOutput.org
  • littleharbor2littleharbor2 Posts: 979Solar Expert ✭✭✭✭
    edited November 2017 #4
    I see very little benefit to these other than, for aesthetic reasons, being able to squeeze another panel in that will spend the majority of its time in the shadow of a vent. Might as well put a dummy panel there.
  • EstragonEstragon Posts: 2,590Registered Users ✭✭✭✭
    If using such a thing, why wouldn't you run the opening to the north side of the array? That would avoid shadowing and provide roof slope to the +/- horizontal part for drainage.
    Off-grid.
    edited November 2017 #6
    That would make more sense than the way it is being presented. Or just relocate the vent from inside the attic.
