About sunswitch in Solar water pumping
kcbibek310
kcbibek310 Registered Users Posts: 21 ✭✭
What is the exact meaning of sunswitch? I have a project in which the owner told us to use sunswitch to reduce the pressure in pump. We are using kirloskar pump of capacity 15 KW and a controller. Can this pump controller featured with sunswitch property or we have to install it separately. If so then can how we install it and suggestion of any brand of sunswitch is highly appreciated.
  • mcgivor
    edited November 2017 #2
    A sun switch is a device which measures the sun's intensity which is used to prevent a pump from operating outside it's power requirements, thereby not pumping. The switch  is placed at the array and is adjustable to only allow the pump to operate when there is sufficient watts per square meter are available. Attached pdf is an example and provides wiring examples, hope this helps.
  • kcbibek310
    Do we connect it with pump controller? How we connect it with pump controller?
  • mcgivor
    Without information in the form of a manual with schematics, it's difficult to say, but some sort of logic input to the controller would be the best method due to limitations of the contact of the sun switch.
