Vinyl Tube lost in Flooded Lead Acid Battery Cell...
openplanetopenplanet Posts: 34Registered Users ✭✭
I use the excellent hydrometer sold by Midnite Solar and other vendors.  Unfortunately, its little vinyl tube is only affixed with a pressure fit, and tends to fall off.  I've now lost two such tubes (about .25" o.d. x about 4" long) in two different cells of my battery bank, and they're proving impossible to see, let alone retrieve.  I've always been fastidious about keeping my battery compartment clean and minimizing contaminants in the cells.  So the question is...will these hunks of vinyl damage the cells they've drowned in?  Thank you.
  • 706jim706jim Posts: 211Solar Expert ✭✭✭
    I don't think they will cause any significant problem.
    Island cottage solar system with 1400 watts of panels, Trace DR1524 MSW inverter, Trace C40 PWM controller 8 Trojan L16's. My 25th year.
  • dexter12353dexter12353 Posts: 13Registered Users ✭✭
    I wouldn't go poking around inside of a cell with a screwdriver or pair of pliers to try and get it out!!!
  • softdownsoftdown Posts: 1,845Solar Expert ✭✭✭✭
    I would think an internet search may tell if vinyl tubing dissolves in battery acid. Such tubing is usually either made of PVC (stiffer) or silicone (supple and more expensive) as I recall.
    Midnite should know the answer...
  • BB.BB. Posts: 27,698Super Moderators admin
    edited November 2017 #5
    You can look up chemical compatibility charts for various materials (page 46 for the following PDF link):
    http://www.graco.com/content/dam/graco/ipd/literature/misc/chemical-compatibility-guide/Graco_ChemCompGuideEN-B.pdf
    Use (I think) the ~50-65% concentration for electrolyte (sulfuric acid+water).
    While a nice dig, I do not see PVC (poly vinyl chloride) mentioned. Nor do we know, for sure, what the tube is made of. Assuming that it is vinyl or PVC is a "good guess".
    I think black hose is often nitrile but can be rubber. Then we have blends as well.
