Battery Bank Capacity
MasterjoeMasterjoe Registered Users Posts: 69 ✭✭
For the Conext 80 600 CC in the operation manual under charger settings the default setting is 440ah. I have 12 390ah L16G-AC batteries. Right now the capacity is set at 1170ah. Am I correct in saying it needs to be set at 390ah?
4.5kw 24v System
18 Solartec 250w polycrystalline panels
Xantrex XW4024 Inverter/Charger
Conext MPPT 80-600 Charge Controller
12 Trojan L16G-AC 20 hour 390ah batteries tied in 3 strings at 1170ah total
  • mcgivormcgivor Registered Users Posts: 1,350 ✭✭✭✭
    Assuming 24V, 3 strings of 4, 390Ah  6v  batteries, the total capacity would be 1170Ah, that would be what is used in the settings, not the individual capacity.
  • MasterjoeMasterjoe Registered Users Posts: 69 ✭✭
    Thank you Mcgivor, that’s what I missed
    4.5kw 24v System
  • mike95490mike95490 Solar Expert Posts: 7,358 ✭✭✭✭
    since your capacity is so close to 1,000 amps, I would set the value to 1,000   It will make all the other settings that work off percent, so much easier.
