Second battery in parallel help
7Hunter97Hunter9 Posts: 11Registered Users ✭✭
edited October 2017 in Solar Beginners Corner #1
Hey folks I need some advice. I just added a second battery to my solar system. I'm far from an artist and do not speak electrical or solar well. Everything I've learned has been from forums and youtube. So please don't expect me to be articulate or artistic. That said, does my drawing of how the system can be set up look right? I'm visual so that helps. Thanks in advance! BTW these are two 12v 100ah batteries.
  • 7Hunter97Hunter9 Posts: 11Registered Users ✭✭
    Or maybe this is a better configuration?
  • littleharbor2littleharbor2 Posts: 1,012Solar Expert ✭✭✭✭
    You need to take the pos.+ from one battery and the Neg.- from the other battery. This forces the charging and load to come to/from both batteries evenly. Very good info at this site.
  • mcgivormcgivor Posts: 2,164Solar Expert ✭✭✭✭✭
    edited October 2017 #4
    Move the positive battery connection to battery 1 and the negative to battery 2 . This will provide better current  ballance between both batteries during charging and dischargeing, inverter connected to same points. Another alternative is to connect all the positive terminals together with a heavy bus bar, do the same with the negative terminals, then connect the controller and loads to the bus bar.
    Thank you littleharbor2 and mcgivor. If I am understanding you both I should configure like this?
    edited October 2017 #6
    Move the positive from the charging source to battery 2 then all is good
    Charging and load (inverter in this case) should BOTH go to the same diagonal points Here you still have charge controller connected to the first battery. Move the positive from controller down to the lower battery.
  • kamchukakamchuka Posts: 55Registered Users ✭✭
    900 watts pv (building on) on poles, off grid 60a mppt, magnum 2k 12v msw, 1400 ah forklift battery (rewired to 12v), 8k diesel gen for house. honda eu6500, 2x 8D, coleman 800w inv for shop, honda 5k for well (pumps to 1000g cistern), ryobi 2k suitcase for mobile ops.
    A picture's worth a thousand words.
    Thank you so much everyone!
