solar battery
johnG
Registered Users, Users Awaiting Email Confirmation Posts: 2 ✭
I have a mighty mule 500 opener and a 10 watt solar panel can I use a 12 volt deep cycle marine battery with this ? I live in western Washington and we do not get a lot of days in fall and winter with direct sun. 10ft gate and it will be opened and shut about 3 times a day at most.
I would suggest, at least a 2% to 5% rate of charge and a small PWM solar charge controller. If you have a 100 AH @ 12 volt battery (good size), then:
- 100 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.02 rate of charge = 38 Watt panel minimum
- 100 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 94 Watt panel nice size
- 100 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.10 rate of charge = 188 Watt panel (gate running all of the time)
- 100 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.13 rate of charge = 244 Watt array "cost effective" maximum
And a simple charge controller like this (with a smaller 4.5 amp maximum output panel):
https://www.solar-electric.com/sg-4.html
https://www.mightymule.com/wp-content/uploads/mighty-mule-gate-opener-planning-guide.pdfWill the Mighty Mule Open During A Power Outage?Yes. A fully charged FM500 or FM502 battery will provide anaverage of fifty (50) cycles (open and close) and the FM350 battery(12 Volt car or marine battery not included) provides up to 1500cycles during a power outage. This number can vary depending onfactors such as the type of gate, number of accessories added, andweather conditions if using solar panel(s) (FM121) to charge thebattery.Ok, from the quote, a "car battery" will run the gate up to 1,500 times on a single charge... Generally, don't want to discharge more than 25% per day for two days, so say 1/4 of that or ~375 times per day:- 100 AH * 12 volts * 1/1,500 cycles = 0.8 WH per cycle
http://www.solarelectricityhandbook.com/solar-irradiance.htmlOlympia
Measured in kWh/m2/day onto a solar panel set at a 28° angle from vertical:
(Optimal winter settings)
A 38 Watt panel would "operate" the gate on an average gloomy December day:Jan Feb Mar Apr May Jun 1.72
2.79
3.37
3.80
4.01
4.10
Jul Aug Sep Oct Nov Dec 4.51
4.65
4.43
3.10
1.99
1.56
- 38 Watts * 0.61 DC off grid system eff * 1.56 hours of sun per day (Dec) = 36 WH per day
- 36 WH per day / 0,8 WH per cycle = 45 cycles per day (break even)
- 1,500 cycles * 0.25 nominal discharge of battery = 375 "easy on battery" cycles without sun
- 375 cycles from battery / 45 cycles per day (Dec charging) = 8 days of no sun, no strain on battery at 45 cycles per day
- If 4.5 cycles per day, that is 80 days of stored cycles
Check the battery state of charge in the evenings (after sun sets) with a volt meter. If the battery is >~12.4 volts in dead of winter, you are doing OK. If lower, it should probably be put on an AC battery charger and given a boost.
Note that Lead Acid batteries do not like to sit (be stored) at less than ~75% state of charge or they sulfate and eventually fail. 75% State of charge is roughly 12.37 volts (use a hydrometer for more accurate readings):
https://www.solar-electric.com/learning-center/batteries-and-charging/deep-cycle-battery-faq.htmlState of Charge 12 Volt battery Volts per Cell 100% 12.7 2.12 90% 12.5 2.08 80% 12.42 2.07 70% 12.32 2.05 60% 12.20 2.03 50% 12.06 2.01 40% 11.9 1.98 30% 11.75 1.96 20% 11.58 1.93 10% 11.31 1.89 0 10.5 1.75
Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset - 100 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.02 rate of charge = 38 Watt panel minimum
sure it will work but you'd be better off with a ~100w panel, you'll wind up having to haul it to the house and manually charge it sometimes with a tiny little 10w panel ..
johnG said:I have a mighty mule 500 opener and a 10 watt solar panel can I use a 12 volt deep cycle marine battery with this ? I live in western Washington and we do not get a lot of days in fall and winter with direct sun. 10ft gate and it will be opened and shut about 3 times a day at most.
If you are using their solar setup but are worried about the long periods of shade, you likely would be better off with a larger panel and the same battery. I think most sealed batteries can take a higher charging rate, often it will be on the battery case. I think these tend to come with a 20 Ah 12 volt battery, from my faulty mind. if It could handel a 1/5th charge 4 amps. a 50 watt panel might work for you, you would get more charging on overcast days and yet be within specs (if it can handle that) on sunny days.
Thanks for the info everyone
