JAM(6)-60-295/PR Panel query
pbdspbds Posts: 1Registered Users
Hey all
Mark Phillips from Tempe
i am looking to find out if anyone has experience with these panels
JAM(6)-60-295/PR
https://www.solarelectricsupply.com/media/custom/pdf/JA-Solar-JAM6(k)-60-Mono-280-300-PR-datasheet.pdf.
With monocrystalline Percium PERC solar cells, the 18% efficient JAM6(k)-60-295/PR solar panel is a reliable solar module for residential and commercial PV applications.
This JA solar panel uses 60 Percium JACM6PW-4 four-busbar (4BB) solar cells, a high-efficiency mono cell using PERC passivated backside and local BSF technology. The 4BB design of the solar cell reduces cell series resistance and stress between cell connection lines and improves the reliability and the efficiency of modules.
JA Solar Model Number
JAM6(k)-60-295/PR
STC Rating295.0 Watts
CEC PTC Rating271.2
Open Circuit Voltage (Voc)39.64 Volts
Short Circuit Current (Isc)9.66 Amps
Frame ColorSilver
OriginChina
Power Tolerance-0 / +5W
Module Efficiency18.04%
Area17.59 ft²
Weight41.89 lbs.
Length65.0 in.
Width39.0 in.
Height1.57 in.
Any input is welcome
Respectfully
Mark
