Solar inverter need help with EAST / WEST facing string on a single inverter...
ChanChan Posts: 45Registered Users ✭✭
I have this inverter where in i have 2 strings each facing east and the other is west,
the problems I see as of now is that the inverter will get both AMPeres and balance everything out, this makes the output smaller than expected, as I check the manual of the said inverter, it has a 2 mppt, based on the SOLAX website "| http://www.solaxpower.com/en/x1-boost-3/   "
eg, 1 string will have 2.5kw while the 1 string has a 1.5kw, this will bring down the amp of the said inverter down...
Is this normal for all inverter to balance the ?
  • PhotowhitPhotowhit Posts: 4,544Solar Expert ✭✭✭✭
    It will be lower, but over a greater time span. For a grid tied system, East and west facing arrays have no advantage that I can see.
  • ChanChan Posts: 45Registered Users ✭✭
    the problem im seeing right now is that the inverter is trying to balance amp and the spec is that its a dual mppt... probably some setting is needed....
  • Raj174Raj174 Posts: 589Solar Expert ✭✭✭✭
    There is a string sizing tool on the website, See if your configuration is valid. You need to make an account and login.
    http://design.solaxcn.com:6180/design/
    12 x 300W Renogy PV, MNE175DR-TR epanel modified, MN Classic 150, Outback Radian GS4048A, Mate3, 54.4V 207AH HI Power LiFePO4 no BMS, 4000W gen.
    yup.. everything is in order actually...
    anyway. im trying to get hold on their customer service....
    Probably a good move. I am not familiar with it, and have only heard of one other in Australia.
